evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Sep 12, 2006 6:04 pm
if you have the skills and toos to pull the turbo's you can have them rebuild for about $300 each, and your gonna want to do both at the same time, if you shop around for replacements you can get a new OE sized pair for about $1200, no way to bypass them
how bad is the oil seal? have you pulled the hardpipes? if you have a small line of oil you can drive ti fotr a while just try to keep out of boost, if however the inside of the pipes is coated your gonna need to fix it or park it
