PUNCTUATION!!!!!blownSR2087 wrote:i have a black top w/ gt2876r turbo 550 cc injectors 255 fuel pump stock internal i am pushin 15psi high flow my best 1/4 mile time is a 13.213 @ 109mph that was with me and my girlfriend in it do u think i am pushin to much boost? and what do u think is the most boost u can push on stock internals but sum fuel work?
That should be okay for pump gas. Do you have a knock sensor or EGT gauge?blownSR2087 wrote:ya i have a wideband when i am in full boost high rpm its about 10.5-11.0 is that ok
WAAAAAAAAA! crybaby.n240sxfnatic wrote:
PUNCTUATION!!!!!
Don't try to make him feel back because the OP lacks an education.blacksrjdm wrote:
Sounds like something you would see in any Fast and Furious movie.10toesdown wrote:Offtopic/
You race at your 1/4 mile with your girlfriend in the car?
Seems to read ok, at least there isnt any crazy ebonics words or anything like that. Go teach grammar if your so special. The both of you.!Zar! wrote:
And
WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA...Just read it and leave an educated comment. or, gtfo.
Because he wants to get a lot of post to be cool...!Zar! wrote:Why can't you form your thoughts into ONE post?
Hope and wishes with an hour or two of buttdyno time.sunnys14 wrote:Only way to tell if you're running lean or not is getting a wideband.
You ran 15psi and only trapped 109? What are you using for management besides SAFC?
with a good ems and tune, the stock engine should be able to handle anything that turbo throws at it. but i would also do the headgasket and headstuds.blownSR2087 wrote:i have a black top w/ gt2876r turbo 550 cc injectors 255 fuel pump stock internal i am pushin 15psi high flow my best 1/4 mile time is a 13.213 @ 109mph that was with me and my girlfriend in it do u think i am pushin to much boost? and what do u think is the most boost u can push on stock internals but sum fuel work?
