masticatingcow »
https://forums.nicoclub.com/masticatingcow-u11112.html
Thu Jun 24, 2004 5:07 am
I don't know about this cylinder bore idea. I've heard of people stroking out the SR to 2.2L with great results, though I would be hesitant to do even that.
If you're REALLY hardcore about dragging, you need to ditch the SR. Sorry. It's really not much of a drag engine, and most people would agree that a similarly tuned and turboed KA-T will beat an SR all day on the strip. FYI, the KA is the stock engine that the USDM S13 chassis was built with. MANY people have turboed this engine with amazing results, considering all the bad press it gets outside of the Nissan community.
It seems like you're in a particularly lucky position. Your dad seems cool and he seems to have all the right friends. If you can pull it off, you should consider a BIGGER engine. A heavy build on a KA24DE and subsequent turbo system will give you some real nice numbers on the track. So would an RB25DET.
However, the more displacement means more torque, which usually translates to better ETs. If you don't care about keeping it Nissan, a lot of people have had luck dropping SBCs in the engine bay.
Of course, if you keep working with the SR, you might have the results you're looking for. Just go into it knowing that it's not the "do-it-all" miracle engine a lot of people seem to think it is.
Good luck!
