I don't like being the bearer of bad news, but then again he said he wouldn't do a 2nd round...lolThe Doc has closed up shop on the kickplates...ballysilly wrote:could you or sum body give me sum contact info so i can get the illumated kick plates for my a/c coupe thank very much to anyone that helps me
this time I'm serious... again, I have run out of material... there won't be another kickplate sale for at least a few months!Summer_In_Brooklyn wrote:I don't like being the bearer of bad news, but then again he said he wouldn't do a 2nd round...lolThe Doc has closed up shop on the kickplates...
yeah, EL tape only comes in VERY limited colors... tha Red is the only Red my vendor sells (called international red)... the only other option would be to order white lights and use trnasparent Red tape... but the light doesn't shine nearly as bright this way... why you gotta rain on my paradesummerinbrooklyn wrote:It's more pink than red...but WOW I still Love it!!!
LOL...cry is what i almost did when i saw somehow, someway i made a tear in the front bose speaker...strategically placed tape(which i did not expect to work) somehow worked b/c i don't hear distortion...rjdmmfl1 wrote:
I actually found a way to do it even cleaner than on the directions... I pulled the black/red power /grpund wire through the insulated material hlding the factory wires, thus ut doesn't come through the hole for the 6.5" speaker... well, I did that on Blake's car...Summer_In_Brooklyn wrote:LOL...cry is what i almost did when i saw somehow, someway i made a tear in the front bose speaker...strategically placed tape(which i did not expect to work) somehow worked b/c i don't hear distortion...
iunderstand what you're saying, but the insulation on that 16 gauge wire is pretty thick.. so thick that 16 gauge splce connectors had a hard time getting into it .... the pressure from where the speaker grill would be pressing on that is not sharp enough to pierce that thick wire insulation...maxentropy wrote:why did you pull the wiring out through the speaker gap? may have issues there if the speaker is securely tightened. I fished mine through where all the rest of the wires came through so I dont get interference or issues with wires wearing out due to the edge of that speaker. I recommend taking off your door and fixing that...
If you don't fix this you risk having your kickplates lose electricity, short circuit your vehicle's electrical system, and even start a possible car fire.
You're telling me! Took me 10 min to get those suckers tight!rjdmmfl1 wrote:the insulation on that 16 gauge wire is pretty thick.. so thick that 16 gauge splce connectors had a hard time getting into it ....
Aye, I hear ya doc, but as they say, better safe than sorry. Only takes 5 min to pop the door off anyway. I gotta tell ya, I am getting compliments all over the place for my kickplates!rjdmmfl1 wrote:the pressure from where the speaker grill would be pressing on that is not sharp enough to pierce that thick wire insulation...
honestly dude, the more I look at them, the more I really like them... and at night.... ohhhh .... I've gotten nothing but love and compliments from evryone that's ever seen them... then I have to hit them with the bad news when they ask if I'll make them some! Hey, they even won your wifey over, so that's all that matters!maxentropy wrote:You're telling me! Took me 10 min to get those suckers tight!
Will do so, i actually had already planned to go back into the door and check on that speaker i popped a hole in, also my neighbor was telling me about some sort of insulation placed on the backside of speakers...they allow the bass to not get lost? Anyone hear of this?maxentropy wrote:why did you pull the wiring out through the speaker gap? may have issues there if the speaker is securely tightened. I fished mine through where all the rest of the wires came through so I dont get interference or issues with wires wearing out due to the edge of that speaker. I recommend taking off your door and fixing that...
