landtodd »
https://forums.nicoclub.com/landtodd-u258.html
Fri Jan 24, 2003 12:00 pm
It's not a perfect reference, but I find the factory manual is useful for several things: exploded diagrams, torque specs (vital!), identification of non-reusable parts, elaborate and exacting parts-replacement criteria, and alternative means of electronic diagnosis when you don't have a Consult. (And who does, other than Dennis?)
The step-by-step procedures assume some background knowledge, just enough to have left me wondering a couple of times. My experience is that common sense is generally sufficient to pull you through once you see the parts for yourself, and then there's this group for when the going gets puzzling.
Lots of illustrations, but some illustration mistakes do pop up. These are usually easy to spot. An oft-cited example (oft-cited by me, at least), the '92 book shows the oil sump as a jacking point when it should indicate the front crossmember, which is also clearly drawn. From what others have said, and from having been in the repair-book business (I was an editor at Robert Bentley, Cambridge, MA) it's my belief that this illustration was correct in both earlier and later books, but some hapless Salary Man messed it up for '92. No biggie, except maybe for him. You'd spot it.
I haven't seen many of the other efforts. My experience is that any non-factory book will be an abridgement of the factory book, with maybe some general, generic procedures thrown in, if you're lucky. I always get the factory book for every older or foreign car I own. The Q hits both those cirteria.
If I read you right, you may be disappointed with the descriptions of some mechanical procedures. For example, if you're doing the chain guides, you'll make lots of use of two exploded diagrams, but the step-by-step doesn't really cover the job. Rather it covers too much. The authors never anticipated changing the guides without changing the chains, too. Deciding what you need to do and what you can leave alone sometimes takes some thought.
If the half of knowledge is knowing where to find it, the factory book suffers. There is so much information that it's daunting when you try to collect everything the book has to say about any particular thing. It's a book that it pays to flip through. An index would be great. You never know where some useful piece of info is going to pop up.
Part numbers? Only for the Special Service Tools (SSTs) at the beginning of each chapter, none of which I've bought yet. Joe and Brian at Scottsdale (or the parts manager at Lisle -- not sure who that is now) are pretty good at helping you figure out what you need, and you're unlikely to get factory parts cheaper, even if you know the exact numbers. At least you'll know the correct names for almost everything.
