qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Sun Dec 05, 2010 12:46 pm
Recently I have been noticing my fuel pump is making noise, but usually only when tank is less than 1/2 full- Now I realize that this is the classic warning that the pump is aging and near the end of its lifespan {has 155,000 miles on pump} and have kept a spare FPCU and alligator clips/ wire leads just in case the inevitable happened.......well today it happened.Started car in cold driveway {35 degrees} and heard the initial 30 second much louder sound the pump makes upon start up when temps are near freezing- thought it was a little extra loud, but all was ok after the initial 30 second drill- drove about 3 miles and all of a sudden I thought, this is strange, the fuel pump went totally absolutely silent{ radio was off}- 1000 feet later as I merge onto expressway the engine dies- pull off to shoulder and upon trying to restart, the dead silence from pump told the story- thought I would just try swapping FPCU to see if the problem was the pump itself dead or the FPCU.......NO screwdriver to remove trunk panel to access FPCU......good god, what happened to that combo screwdriver I had always kept in the cargo net????/
Since it was freezing out with 30mph winds and no way to fix on the side of the road, called the flatbed to drop off the Q at local shop and returned home- what a day,the Q has its first breakdown requiring towing and stranding its owner {that maybe a simple stupid screwdriver could have prevented}
