Ignorant Fool
Hialeah240sx
I just bought a stick-shift 1993 Nissan 240sx. How can I find out if the engine is KA24E or KA24DE or what?
Also, how can I find how much HP my car has? And any other specifications that might be helpful?
Also, a friend of mine told me that my engine looks like a 1996 240sx engine. Is there any way of proving or disproving this?
Thanks! :cool:
Rownan
Your engine is the KA24DE. Dual overhead cam, 2393cc. Yes it is identical to the '96 engine.
At the crank, it makes 155 hp@550rpms, and 160 ft/lbs@3600rpms.
Timhttp://www.projectaspec.com
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
The 96 has way way more vaccume lines for emissions garbage, internal coil distributer, and the list goes on. But yeah its almost exactly like a s14 engine.
Also depending on the build month you may or may not have the 240-248 cams and secondary butterflies aka swirl controll valves.
edit: for future reference dont post the same f'n thread in every forum you see. Its a waste of time, and is annoying.
austin240sx
Car: my car
here is what you do: remove spark plug wires, then spark plugs. take off the valve cover-if there are two cams-you have the ka24de, if there is one cam-its the ka24e-if there are no cams-put everything back together and sell your car!!
Structure240sx
austin240sx wrote:here is what you do: remove spark plug wires, then spark plugs. take off the valve cover-if there are two cams-you have the ka24de, if there is one cam-its the ka24e-if there are no cams-put everything back together and sell your car!!
first u dont have to remove spark plugs to take off the coversecond all u have to do is read the valve cover "TWIN CAM 16 VALVE" if u dont know which engine is which
quiksilvia
Car: 95 s14 se
but his way was a lot funnier
Hialeah240sx
thanks for the help! :) sorry for the multiple posts...
