NISSAN_GUY_1987 »
https://forums.nicoclub.com/nissan-guy-1987-u44340.html
Wed Oct 04, 2006 1:32 pm
So here's my symptoms. The car jumps in and out of the problematic stage. drops about 500rpm and sounds like a damned lawnmower and stinks of gas. Sounds like it is missing. Checked for spark across all 4 coil packs. All get spark but #1. Harnesses for coils are all good. Coil packs are all good. All injectors are pulsing and getting power. When the car is acting up, it loses spark to the #1 coil. The ignitor switch is HOT when the car is acting up. I have heard that this usual means the ignitor switch is bad. I plan on replacing it on my next pay check but I wanted to see if anyone else has ever had the same issue. I will also be looking for an ignitor switch. Is the Q45 the same or do you have to rewire the plugs? Also, does the Suzuki switch work for the SR? I have heard rumors of a recall on the Ignitor Switches from back in the day... Not sure on the time frame. Any help?
