rb25drag »
https://forums.nicoclub.com/rb25drag-u76935.html
Wed Aug 27, 2008 3:16 pm
Hmmmm, Kinda sound like the same issues im having except im on the s2 rb25, I don't have an ignitor, Mine seems to blow the spark out of the coils, Or so it seems, But I have not UnHooked the Gizzmo completely and tried it on the stock electrical system yet. Maybe you should give that a try.
The First Gizzmo I bought was a bad unit, it would Misfire and loose a cylinder under idle and sometimes on revs, I checked the wiring 100times nothing out of place.
They sent me a new unit and it worked perfect, Until my last visit to the track, The unit seems to activate right and it misfires the engine the same, But im blowing spark out under boost BAD. I assume its my coils, Im on stock ones. But im going to Upgrade to the Splitfires soon.
have you tried a Lower boost? I put mine back on 7psi and it ran fine. So it seems to be a spark issue on mine. But i have had Trouble in the past with the Unit. Gizzmo was very helpful when I had my problem, They worked with me very well, I would suggest giving them a call and seeing what they suggest.
