Under what conditions does this solenoid switch the FPR reference from the intake manifold over to atmo? What's the reasoning behind it? What would it cause to skip out this part, and just plug the FPR straight into the intake? Could it cause a lean idle (JUST idle)?Spawn_CA18 wrote:there's no boost solenoid on the CA18DET - what you're looking at is the hot start solenoid - doesn't control boost, just usually breaks and causes the car to run lean.
it does this by affecting the vacuum/boost that the FPR sees (you'll see there's no connection to the actuator at all).
Everytime engine start and no vacuum to FPR for a period of 180 seconds, you can find it in EDM FSM EF & EC -20blownhemi wrote:Under what conditions does this solenoid switch the FPR reference from the intake manifold over to atmo? What's the reasoning behind it? What would it cause to skip out this part, and just plug the FPR straight into the intake? Could it cause a lean idle (JUST idle)?Spawn_CA18 wrote:there's no boost solenoid on the CA18DET - what you're looking at is the hot start solenoid - doesn't control boost, just usually breaks and causes the car to run lean.
