9240sx wrote:What could happen to it if its zip tied?Iv had mine this way for years.
excessive vibration is one side effect of zip tie-ing it in place. Unless it's mounted to a plate via bolts, it's gonna vibrate around as the car does. Second, it looks bad. Zip ties are good for tying back wire bundles and holding a few things in place, but should never be used to mount critical components.
mmashburn wrote:i dont understand why you say it's hot on the passenger side of the engine... the hot side is the exhaust manifold side... it's doesnt get that hot right around the intake manifold and cold pipe..
That side of the engine bay is cooler than the driver side by far, but when I say put it in the cabin, that would be the optimum place for it. The engine bay gets heated unless you vent it, so the passenger side of the bay still sees heat. The best place to put the ignitor would be a spot that doesn't see much heat, such as the passenger side kick panel. It's why the ECU is placed there.
I mount ignitors on the passenger side of the engine bay.
