Ignitor Chip install
9Dsx_Drvr
Car: 90 240sx
I downloaded the q45 ignitor diagram from "HeavyThrottle.com
http://srownersclub.com/faq/site/q45.doc
and I am trying to wire it next to the ecu instead of under the hood. I have a #62 ECU. with s13 blacktop. 1. Can I wire it there?2. Will the #62 work or do I need the E5?3. Is ECCS the same as ECU? Looking at the diagram, they have pin 1- to Coil pack 1 pin 2 to coil 2 etc. etc.On the other end you have pin 21 to ECCS pinout 1, pin 22 to pinout 2 etc. etc. On a schematic I of the ECU pin 1 is coil pack 1 and pin 2 is coil pack2 etc etc.Also the colors are different on from the Heavy throttle and the ECU diagram.
1. Am I confused on the pins? Both sides of ignitor go to the same place.2. Do I just wire up according to Ignotor schematic colors?
Thanks
9Dsx_Drvr
Car: 90 240sx
I email HeavyThrottle and have not got a response. Has anyone every email them and got a response?
I really need help I am trying to get this car running by the end of the month.
mallbor240SR
Car: 240sx 1990
where was the stock ignitor located at? if it was at the drivers side strut tower then , someone extended the wires when doing the swap thats why the colors dont match. try tracing the wires back till you find the stock wires.
9Dsx_Drvr
Car: 90 240sx
Never mind.I went on a site and they mentioned the wires from the harness going to the AC and the power steering that also included the wires to the chip. So, I pulled out the harness and found the corresponding wires that go to the chip. Duhhhh!!! If I would have look where the stock chip would have been I would have figured it out.
Thanks anyway
