Ignition woes
AlkYMiXr
Car: 1992 Q45
ok so i have already run into the first problem with the Q I have read a bunch of ignition problems threads but none seem like mine When i try to start the car the key goes in fine and turns fine but when turned to he start position nothing happens if i turn the key back and fourth a few times (from the start pos to the off pos) it "sometimes will start seems to me there is a loose connection is this common ? After reading the other threads i dont want to go to far and screw up more than i need to to fix it like some others have done.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
You might need a new ignition lock. Then you have to decide what to do about the door, glovebox, and trunk locks.
If PO was a building superintendant and kept 2 lbs. of keys hanging off the ignition, it is most assuredly worn out.
AlkYMiXr
Car: 1992 Q45
Hmm could be im hoping not... The PO had the same tase as me in keys and has nothing else on the car rings but the car keys all other keys house work,ect are on there own ring ( this also makes it easier to take different cars if you have more than 1) As far as the key cylinder it turns freely in both directions and the key does not have much play inside of it.... However i did notice that if i turn the lights on when trying to start it i get no dimming of the lights at all..??? I have wiggled everything while turning the key to the start pos ( shifter , key , stering wheel. Also both batt cables are tight on the batt
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Well, you might remove the lock cylinder or at least check it's connections.
Something's not right.
AlkYMiXr
Car: 1992 Q45
Yea i just got back in from checking the fuses and what not trying to use FSM's trouble shooting page for starting but ..... well i guess if i cant figue it out ill just go to a push button start .. Also just to add this for trouble shoting purposes i have 3 keys and have tryied them all not sure why it would be any different but i did it anyway After removeing the cover over the ignition cylinder it looks like all the connections are on the unit it self can be wigled from left to right but only about a 1/4 inch in both directions. I am really stumped. For those who like all the info This Just happened it did not show any signs of slow or hard starting just got in turned key and had nothing
Modified by AlkYMiXr at 2:36 PM 10/4/2007
AlkYMiXr
Car: 1992 Q45
I have done some searching and found on other nico forums that they ahve this problem on a few other cars and some have traced it back the A " ignition relay wire behind the battery" do we have this wire on the Q i do here a very quite click when i try to start it seem to be in the upper left side of the engine compartment almost behind the abs stuff near the wiper motor
96Qowner
Car: 1996 Q45
I found these threads about the ignition switch - some good diagrams in one:
92 Q power lock relay
Ignition Switch or ECU
Q45 ignition switch fading fast
1994 Q45a Starting Problems
And there's a possibility it involves your starter or its wiring path:
95 Q45 intermittant starting problem
AlkYMiXr
Car: 1992 Q45
Thank you i am gonna run with a few of the ideas i found in those linksI tought i had looked over the boards fairly well (guess not ) thanks again
96Qowner
Car: 1996 Q45
Sorry I didn't make the connection before - you're the one with the Q out of Florida that's been sitting for awhile.
I'd look the relays over real well - probably should plan some time under the hood to check and clean other connectors like the MAF and CAS, too (not related to this problem).
AlkYMiXr
Car: 1992 Q45
i am trying to check the realays no my friend has my vom and is returning it today but in the mean time if the relays are clicking does it mean they are working ????
96Qowner
Car: 1996 Q45
Not necessarily. I believe you can swap 'em though, color for color. If the problem moves - bingo!
AlkYMiXr
Car: 1992 Q45
WOOT i traced it to the relay behind te abs!!!That being said 96Qowner you are right about the clicking and not working thanks for all the help everyone
