Ignition wire location in engine bay Versa/Tiida
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Suavsilk
Car: 2007 Nissan TIIDA ST Sedan
Title speaks for itself.
I am installing automatic headlights onto my tiida, have wired everything up fine except i cant find the damn ignition wire under the hood.
If someone knows how i could find it, could you please help!
Would it be easier to run a wire through into the cabin? if so, how? and.. that would be handy to know anyway lol..
Thanks in advance, heres some pics to show what ive done:
Ignore my ticks, they are lies. I thought i found the ignition wire but it was something else and i blew a bunch of fuses when trying to run the headlights.
Suavsilk
You know when you get to that point and say "Ok... ive f***ed something up here..."
Ok so i cant find the ignition wire, so for a temporary fix i decided to wire it directly to the battery with a switch. It works, but i keep blowing fuses.
I think i have attached the wires from the control unit to the wrong wires in my car. The wires i have used were found by trial and error (so yeah... probably the wrong ones)
Also... in hindsight, opening up the ECU box is probably not where i should be messing around.
Could someone help me find the correct wires to install this thing properly please.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
You want a power source that is controlled by the ignition, correct?
Suavsilk
Correct, i don't want the light to automatically come on if its dark and the engine is off.
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
The diagram I have for an '07 Tiida shows a blue wire going into that distribution block that is controlled by the ignition switch. It's supposed to be position #4 into a 40 Amp fuse.
Suavsilk
mine is an '06 model, would it have changed?
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
I don't think it will have changed, but I would use the multimeter in your picture to verify that is the correct wire. It should not affect the circuit or blow a fuse using a multimeter.
Suavsilk
aurgh i give up D:
cant find it, i swear ive tested every wire under that hood. all but the correct one apparently.
Im going to get a mechanic to do it
Return to “Versa Technical Discussions”
