Ignition Wire Colors
mick
Car: 1990 240SX
I want to put in a kill switch. Should I put it on the white wire?And the blue wire seems to be the switched +12 volt line. If I want gauges to switch on when the car is on----do I use the blue wire?
Vegascorbin
Car: 1990 240sx dirt track race car
Are you looking to put in a total kill like some race tracks require or just a way to turn off the motor without useing the key. Or are you looking to install a hiden switch as a theft deturent?
Differant answers depending on what you want to do.
WhiteKnight
Car: Nissan 240SX
I also need to know which wire you would put a switch on for preventing the car from starting.
89twoforty
Car: 89 fastback
I'll assume you're talking about a fuel pump kill switch. Here's a write up on doing it, the pictures are broken but it's fairly simple.
zerothread/215861
WhiteKnight
Car: Nissan 240SX
What I want to do is put a switch into the wire that turns off the engine when the key is switched off. So if the switch is open....the engine would never start.......although the starter will turn.
engineperson
Car: 91' Nissan 240sx coupe Ka24De
i just tapped into my fuel pump fuse and stuck some extended wires where the fuse was and put a switch where the fuse was. i just put the fuse inline w/ the wires. the car can start, but it'll die after a few seconds after it loses fuel pressure. thats my hight tech alarm anti-theft system. (only used it once)
mick
Car: 1990 240SX
The blue wire from the ignition switch is 12volts switched. So when you run the engine you always have 12volts there.
mick
Car: 1990 240SX
I found that out..........I just wanted to confirm here. Which is the wire that trips the starter?
