nismofan14 »
https://forums.nicoclub.com/nismofan14-u3055.html
Mon Oct 13, 2003 8:04 am
Ha, Thought the diagram they sent me was no good. The one they sent me has the 2 wires that are on the coil harness being the only ones used. Here is the link to the diagrammsd diagram So if you say that I have to tap into that signal wire, I would do that on the harness for the camshaft position sensor since the 2 wires they told me to use do not emit a signal? I am assuming that you have done this install so maybe you know which wire it would be? Thank you for your help.
