Nicka619 »
https://forums.nicoclub.com/nicka619-u153356.html
Sat Aug 07, 2010 9:20 pm
Hello, ive been registered to nico for quiet some time, but never actually posted
I own a 91 240sx, ive had her for bout 3 years now, but was never running. Now i recently got her running!!! Rebuild the motor =D Had to replace the fuel pump from sitting so long, but now i am having idle issues. My motor is very shaky and doesnt remain stable. Ive recently replaced parts that were bad already, including the MAF, knock sensor. Today i cleaned out my idle air control since i didnt when i had the motor out, just to see if it helped.......no success O.o
Now, to get to the problem i am having. Every time i go to do the ignition timing, i can get it to time right on to 20 degrees. But when i hook up a scanner to the car and made sure everything was right, i noticed the computer was reading the ignition timing as 0. Strange right? Is this supposed to read at 0 or at 20? I have no idea where the car gets the reading from and if that part is bad or what? Does anyone know any problem similar to this? I was guessing the distributor reads the ignition timing and can be bad. I did get this dizzy from the junkyard too O.o
Any advice at all? All is appreciated. Thanks! =)
