Post by r3v_v3ng3 » https://forums.nicoclub.com/r3v-v3ng3-u58043.html Wed Jan 27, 2010 8:11 am
Post by nate00 » https://forums.nicoclub.com/nate00-u146416.html Wed Jan 27, 2010 1:45 pm
thanks cause somebody told me it was done through ecu codes? made no sense. maybe he was talkin bout the CAS?r3v_v3ng3 wrote:unplug tps set idle to 700 rpm then set timing through distributor while checking it with timing gun on the crank pulley (20 degrees)
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
