USDM_OneVia »
https://forums.nicoclub.com/usdm-onevia-u6319.html
Sun Nov 02, 2003 5:07 pm
Ugh..... I've had enough.
I set my timing at 15 degrees per the factory manual, set it when cold, rechecked when car was hot, still at 15 degrees. Well... the car runs like crap. Hard starting, missing when cold, and it has a dead spot right when it transfers over to boost from vacuum. I can get on the gas, but there is a slight dip in the power and then it is hold onto your hats......
Now, if the timing is dialed back to almost 25 btdc, it idles smoother, runs better during warmup, and has a smoother powerband, but not as powerful as when the timing is advanced.
What am I doing wrong here? I know I can't run it that far retarded because a rich condition and not enough timing is a recipe for detonation. Any ideas?
Also, I have noticed that the temp gauge does stay at about 1 bar higher than my stock KA does on the cluster. Could this heating problem affect my timing/running issue? I am at my wits end here..... I finally get the car running half way decent, and it is just little things I am cleaning up now.
Also, any ideas on a "fast idle" during startup? Mine likes to idle at about 550 rpms when cold, and is like a rock at 800 when warm (where I set it at). Almighty Dee want to chime in here???
Joe
