xero1 »
https://forums.nicoclub.com/xero1-u19721.html
Tue Oct 17, 2006 1:46 pm
i found a old post about checking ignition timing using a timing light, the old post said to get engine up to opperating temp, disconnect TPS, connect inductive pickup lead to black wire ground wire that come out of the ignition coil harness. is this correct?
