VenCountyQ »
https://forums.nicoclub.com/vencountyq-u9446.html
Fri Sep 05, 2003 11:15 am
You simply look for a bracket attached to the power transistor on the passenger side of the engine. This bracket secures 1 or 2 small connectors. Look for the connector with a single wire ( the top one on my 94Q ). Clip the inductive pickup around this wire. I don't think it matters which side of the connector, but I clipped onto the side pointing at the radiator. Run your timing light as you normally would.
This procedure is in the FSM, but it falls short of identifying the connector explicitly. The FSM also doesn't make explicit mention of any procedures required to eliminate ECU advance/retard adjustments in order to ensure one is measuring base ignition timing. Typically one has to use a jumper on an identified check connector or disconnect some connector. Because the FSM didn't explicitly identify the need for this I simply made sure the engine was at operating temperature, idling and the AT in neutral. The timing mark read 14-15 degrees BTDC.
There is mention of a check connector near the firewall in order to connect a tachometer during a timing check, but the FSM says nothing about needing to use this to ensure base ignition timing is in effect. I have seen mention in a TSB about disconnecting the throttle position sensor when setting idle speed/timing. I also remember Q45Tech mention disconnecting something on the IACC when checking timing. So I am still slightly uneasy about whether I was truly measuring base ignition timing, but the timing mark was steady and at the correct setting when I did my measurements. If the engine is making advance/retard adjustments you will sometimes see the timing mark fluttering.
