corey170 »
https://forums.nicoclub.com/corey170-u74444.html
Sat Jun 06, 2009 3:37 pm
So a couple of days ago my starter died, when i turned the key there was nothing (not even a click). Jumping it didnt work so I had my friend hit the starter while i turned they key and voila, it barely started. I had it figured on brushes but got a whole new starter anyways. i installed it and now I'm having a different problem, when i turn the key it just clicks and the starter doesnt turn. This problem is intermittent, happening ~every 7 times. I took it back to the guy who i got it from and he started the motor fine (several times) using a jumper cable connected directly to the battery. He then continued to tell me that it was most likely my ignition switch that had gone bad.
Any ideas?Thanks.
