Ignition system
KA-24 N/A
I am trying to get a MSD ignition system or a HKS twin power (distributor type )does anyone have reviews on this .... on which product is better for the money ......
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
if you are reffering to ignition boxes, i have heard they are a waste.
allthrottlenobottle
Car: 91 s13
msd ignition system number 6A is a great system but you need the tach adapter part # 8911 or 8910 (cant remember its been so long)
allthrottlenobottle
Car: 91 s13
their not a waste but with more spark you need good plugs/wires etc. it all depends on what your looking for out of a multi spark ign system.
Drifterxl
Car: 1990 240sx FB
your aftermarket ignition will also get rid of that annoying restrictor plate, so just incase your ever in the mood, you can hit speeds above 180km (108 m) which is always a plus in my books. and as allthrottle mentioned, bigger spark, which means better response and acceleration.i was thinkin about doing this as well, and when/if i do, i'm going with the msd ignition.
allthrottlenobottle
Car: 91 s13
i installed the 6A system in my friends 89 SOHC and it works great,but just remember you need the 8910/8911(?)tach adapter to make the system work.
KA-24 N/A
Thats what i was thinking.. is ther any bad side to installing the msd ignition .. ?just curious..
allthrottlenobottle
Car: 91 s13
plugs go a little faster,but i havent seen any other side effects(ignition lag,over firing,etc.)the systems is pretty simple and reliable
