zippakilla »
https://forums.nicoclub.com/zippakilla-u128140.html
Tue Aug 11, 2009 7:41 am
Alright so a little background on this.
Its a 1989 240 with an RB25det. Was an Auto to manual swap. I finally got the car running after 3 months and it was running great. Took it in to paint it. put it back together drove it around notice when i hit a bump the RPM's would drop, Pulled up to a stop sign and the car died.
I have juice to the dome light the head lights and all that non sense but when i put the key in and turn it on there are no dash lights (clock works) no seat belt movement no fuel pump Nothing.
Try different batteries nothing. So i tow it home and start looking and its the starter switch 30A fuse on the passenger side fuse box. I traced it back and notice the White plug it goes to under the steering column was turning black around the wire. I put in a new ignition switch and i started it and felt the wire was getting hot along with a Blk/Wht wire. so i figure its the 12v constant grounding out somewhere instead of tracing it down i ran a new wire straight from the fuse box to the switch. Nothing changed. I know people have had this problem but i didnt see any clear explanation as to how to fix it. thanks for any help.
Modified by zippakilla at 10:58 AM 8/11/2009
