Ignition Switch Relay
R4KA240
Car: 1990 coupe with "Stock" KA24E, 1994 Convertible, 1989 coupe (motor T.B.D.)
I've had a wiring problem with display lights staying on after key is off/out, its the ignition relay being kept stuck open, Does anyone know where the grounds to this relay are? I can't get back there to trace the wires... Thanks, also, anyone know why my popups would go up ONLY when I push the button, then not go back down unless I crank them?
