ignition switch rebuild
92finityq45
Car: 1992 Infiniti Q45
do any of you know how to get the key part of the switch out so it can be rebuilt ? some times the key does not what to turn.
come on someone must know how to get the lock cylender out is there a trick to it?
Modified by 92finityq45 at 5:38 PM 9/4/2008
dusred
Car: Previous Q45 owner, 09 Corolla, Ford F250 Diesel truck
I would take it to a professional Locksmith; they will be able to figure it out for you. My Q does the same thing when I use the original key that came with it. I got a fresh key made and I haven't had any problems since.
Q451990
The eitire ignition switch must be removed... it clamps on to the steering column with "sheer head" security screws that must be drilled out. You can order replacement screws, or just put in Hex head screws with the proper thread size.
Although some locksmiths can rebuild these, I would lean toward replacement unless you really trust your locksmith to tell you if the problem is worn wafers or other worn components in the lock.
Heath
