Ignition rewire
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
FixItkid
Car: 1982 Datsun 720
Trying to put in stock ignition switch and taking out hack job and I need to know what wire is but what
What is the difference between white with red stripe and whit with blue…?
FixItkid
Help me!,,
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I can't access wiring diagrams back that far, but Nissan/Datsun ignition switches pretty much all have the same 4 or 5 wires, so some of it can be deduced from the present hookup. One will be battery supply in, that will be your WHT/BLK. The "Start" terminal output looks to be BLK/RED, that will be the trigger wire for the starter solenoid. The remaining wires will be Accessory and Ignition, and it looks like he wired them both to the Ignition terminal. To figure out which is which, jumper them individually to WHT/BLK and see what goes hot. The Accessory wire should power the radio, the Ignition wire should power the stuff in the engine box.
mdmellott
Car: '13 Kia Soul+ 2.0L AT
Wiring diagrams are included here. >>> https://www.nicoclub.com/service-manual ... Manual.pdf
It looks like WHT/RED (WR) should go to Accessory and WHT/BLU (WL) goes to Ignition.
Return to “Datsun 720”
