I recently put in a new distributor. Got everything lined up and she fired right up. Drove for a while, turned the car off and went to the store. When I got back, she would crank but not start.
Pulled the fuel plugs, they weren't wet so I was pretty sure I was getting spark. Pulled the fuel return line (a huge rush of fuel came out), put it back on and she fired up again.
Replaced the fuel filter thinking it might be clogged. Again, she'd crank, but not start. Adjusted the distributor a little and got her to fire up again. Finally pulled out my timing light, looks like I'm at about 5 to 10 degrees BTDC, I think I should be at 15 but can't get there without moving the distributor another tooth. What do yall recommend?
I checked fuel pressure a few days ago when trouble shooting the distributor problem. Got up to 40 PSI then slowly dropped when turning the key to the on position. Any help is appreciated.
