alms24sebring »
https://forums.nicoclub.com/alms24sebring-u50673.html
Tue Feb 01, 2011 9:21 pm
So today I get in my car and nothing happened when I tried to start it. I looked around to try and narrow down the problem and I think the ignition is bad but not 100%
If I put my key in the ignition, the beep goes off as it should, but after that nothing not even the radio. The lights and door locks work as they would even with the key out, but no power windows or radio as mentioned when in ACC or anything after. I dont hear any relays go off when I turn it to ON like fuel pump, dash lights, etc, and no attempt to crank. I tried jumping it just to make sure but as I thought that did nothing because I have power and bright lights. No blown fuses either. It sounds like the ignition is not sending the signal to turn stuff on. So my question is what else could it be besides an ignition?
On a sidenote, there are 4 relays next to the fuses in the interior fusebox but I dont know what they are since the cover doesn't tell me. But I have never seen a bad relay anyways.
Any opinions?
