BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Sun Feb 26, 2006 7:21 pm
Sounds like a boost leak, pull on all of your intercooler piping to make sure it is attached securely. A bad MAFS can also cause this problem but I doubt thats it since it only happens when you try to accelerate. When you step on it, you create boost, which will push loose pipes/couplers away, making the engine dump fuel for air that it never gets.
