all the dash lights will not light up (as if the battery got disconnected) but I try reinserting the key in > turn it then it will start although it takes a couple of tries before it finally turns....
now I looked under the hood and there seems to be some water in the fuse box splashed there somehow because of the strong cyclonic winds / also checked the ignition fuses (80a and I 4got the other)...battery is somewhat wet too...put a shop towel in between the fuse box cover closed (after wiping the excess water)...so far I made it back to work typing this
is this just moisture affecting the ignition??? should I put clingwrap around the fusebox to avoid this problem??? or what?
