ignition problem
ranziel
Car: 240sx convertible 300zx tt
hello guys im the proud owner of and s14 kouki automatic ill post some pic later but right now im in a bit of a problem here . the ignition switch in the s14 is bad and the key thing is too i decided to go for a GTR push to start i already have on coming. im been searching like crazy today i need some help in doing the wiring and the schematic of the ignition switch i already got the ignition lock assembly off. i searched and all i could find was to do it with the push to start with keys in it but to late for that i have seen i a website that i would need 3 relays and another on and off switch i can get does i just need to know how to push everything together right. this is the only car i have and i would really appreciate if u guys could help .
thank u
:ohno:
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Get a test light and check to see which wire is + at all times. Make that the main wire that powers all your toggle switches and push button. Then run the rest of the wires to the other parts of the toggle switches and the black/white wire to the push button. That way each section (acc, ign on, and start) will have its own toggle and button. Viola ..... No more keys.
ranziel
i would like to just use the psuh to start to control the acc on and off and the ignition like some other cars
compactfean
daily
You mean like the new cars? There is an entire computer that controls that. You would have to find an aftermarket company that made that and wire it in to the computer and the switch.
ranziel
oh i saw a this video http://video.cardomain.com/VideoPlayer.aspx?id=2202506 but this guys doesn't make them any more . there is a site that sell them but 250 with shipping but its come with a remote security system with i don't want because i have one ... the may setup it seen simple with just relays i can get those and the gtr switch its on its way so i just like a way to put it all together .
ranziel
compactfean
daily
After seeing that video, it seems simple enough to wire with some relays. Just need to kniw what each pin does on the button and then go from there.
ranziel
compactfean wrote:After seeing that video, it seems simple enough to wire with some relays. Just need to kniw what each pin does on the button and then go from there.
yeah i would like to do it this way but i need to know what color wire does what and what goes to what relay and with wires do go to together
compactfean
daily
Looks like you have some homework to do.
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
I think you will find some help at The12volt.com, check out the wiring for remote start alarms. I do know that on S13's (not sure about s14) there are two circuits that need energized to start the vehicle, one for cold start and one for hot start. Usually the second circuit gets overlooked by novice installers and it results in the car not starting when cold. You will also need to instal some sort of lockout device, RFID, or other to keep the car safe when unattended. Otherwise....smash window, press button, drive it like you stole it!
ranziel
thank u man im gonna check it out and wait until i get my gtr push to start and i'm pretty sure ill come up with more questions
