groundhogday1976 »
https://forums.nicoclub.com/groundhogday1976-u4144.html
Sun Mar 07, 2004 5:30 am
Well, stupid me, I did forget to purge all the air. That involves just removing the bolt from the burp hole and letting the car run until it stops spitting air, right? I did that and it took a long time to get it to stop burping air, but after that the car still dies after a while and the temp gauge is normal. The coolant temp connector isn't corroded and wiggling the MAF connector doesn't make it stumble while it's running. I haven't found any bad fuses yet, but I'm gonna check again just to make sure. The first step in the diagnostic procedure for "Engine Stalls When Hot" in the FSM said to disconnect and plug the vaccum line from the fuel pressure regulator and see if the stalling goes away. If so the fuel is bad. Do you think that's worth a shot? I did go ahead and try the coil and it didn't help so I took it back and got refunded. I ordered a cap and rotor while I was at it. I don't know if that has anything to do with it, but it's cheap and I'm due for new ones anyway. I'm goin' out of my mind here. I still have to have the transmission swapped and get some other little things done so I can run my car on the 20th, and now I can't even drive it to the shop to have the swap done. Not to mention I'm starting a new job next week where my car will have to be in top condition.
