ignition problem
lost-and-found
Hi guys 'n' gals.
I recently purchased a used 1990 Nissan Stanza, in a very good condition, only 54k miles on it.
I noticed one problem today....
The ignition switch is the kind where there is a button by the key that you must push to get the key out. Normally, if the car is left in gear (automatic transmition) the key would not be able to push, thus preventing you from taking out the key (a safety mechanism). Well, I can leave the car in any gear I want and take the key out, that's not my main concern cause I don't intend on leaving the car in gear anytime soon. Now, let's say that I DO leave it in gear, I'm able to take the key out. If try to get the car started, then I can't , the starter is not even starting, the lights and equipment (radio) turn on, but the starter is not working even. Now, if I move the lever back to P, something's broken in there too. If i don't push the lever very, very far, until it can trully move no more, the mechanism keeps on thinking I'm in gear still (I'm really in P cause I can take my foot off of the brake and not move), so if I turn the engine off I won't be able to start again. I have to "force" the lever to the front end of P and then be able to start. That worries me kind off, what could it be? I'm worried cause I now have to remember to move the lever all the way to the end, with force, before I turn my engine off, and that will get tedious.
edit - someone told me that it might be the inhibitor switch, or something (I really am not knowledgable in cars). Could the inhibitor switch make me move the lever all the way to the end of the P position if I want my engine to work again after I turn it off?
NISTECH
you just need to adjust your shift lever at the trans. the electrical switch in that area is the inhibitor switch it also has a slight adjustment .
