LEMHEAD16 »
https://forums.nicoclub.com/lemhead16-u7080.html
Mon May 30, 2005 5:40 pm
When I use the real time viewer on my E-manage I get a crazy ignition signal. If I hold it at a constant RPM the viewer wil bounce around from 2300 to 4542 RPM. Do I have to put some kind of filter on the ignition input to the E-manage brain.
Also If you look at the map below you will see that it bounces up and down and then when it misses It will shoot all the way up to 65000 RPM (not a type-o). My car has always had this miss but I couldn't see it until I installed E-manage. Any Ideas as to what is causing this miss. I have replaced cap and rotor, plugs and wires with no change.
Any help would be appreciated!
Josh
