sandydennis2326876 »
https://forums.nicoclub.com/sandydennis2326876-u245696.html
Sat May 07, 2016 11:41 am
Here with '96Q that the key FOB does not work but original key has been working fine until this morning.(Note, using key in truck sets off the alarm, but not the doors)... For no reason after entering the car, I could not get the key to enter the ignition. Pressed button next to ignition, no movement. So manually locked doors,then unlocked the doors, pressed brake, Tried to move shifter but not moving. Still no luck.
Then all of a sudden the key would go in and the Q started.
Never had this issue. Issues with the FOB in past, but not using it because is doesn't respond and infiniti service was not able to get it to work months ago with previous FOB issue.
Not looking forward for this to happen randomly . Any thoughts.
Owned since new with all service and lots more.
Thanks
