ignition key replacement 350z
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
richie-g
Car: nissan 350z coupe
Hello everyone, I have a 2005 350z fairlady Japan imported into UK . I only have one key which operates the doors and ignition > i Understand that my key works on 315MHZ instead of the usual british model 433 mhz can i obtain a key for cutting which will work on 315 mhz when programmed ?
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
I've got to admit, that's a question I've never heard before! I'll poke around some true JDM sites (you know, the kind where I actually have to use Google Translate!) and see if I find anything.
This has me wondering what frequency the US keys use.
trusovici
Car: 2004 350Z
1996 Pathfinder SE 4x4
ive bought cheap uncut keys from ebay in the U.S. and they always worked. id say but one and see if it works, the only expensive part would be to get it programmed. I paid $65 dollars to get it programmed and cut.
Return to “350z / 370z Technical”
