DJButton »
https://forums.nicoclub.com/djbutton-u27091.html
Fri May 02, 2008 9:34 am
As the title states, ignition is cutting out with WOT and under full boost (stock 10PSI) Ignitor is relatively new and worked fine when I drove the car back in December, also thought a coilpack could be the culprit, but I replaced it and moved them all around as well. Under normal driving it's fine, and in most gears even with WOT wont happen until above 4k RPM's. We're trying to figure it out but I thought I'd give you guys a chance to chime in with your thoughts. * oh, and don't tell me to check MAFS, wiring and all that stuff, the car did run fine and nothing has changed with that. The problem first started about a month ago, when my alternator died. *
Thanks,Dan
