evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Jul 12, 2007 7:07 am
the timing simply moves when the spark occours, as for the injectors, the sidefeeds burried in the manifold should be rpetty quiet, and if you can hear them click then I'd say you're fine there, and you've already determined the problem to be spark right? I'm not too familar with the system on the Z32 does the cas send only one signal to the ecu or 2 like all earlier z's? although you already tried a known working cas.....so next step would be the ecu, if you have access to another car it might be worth swapping ecu's
