maxnix »
https://forums.nicoclub.com/maxnix-u127.html
Wed May 02, 2007 2:02 pm
Welcome to NICO, arjoe.
There are a couple of treads on this, probably in Infiniti Online Mechanic.
First, you need to know which cylinder is sending the misfire code, then you need to switch coils and monitor for the next misfire code. It it follows the code, then voilá.
Presume you have ohmed your injectors, checked your O2 sensors and cleaned plenum, EGR and IAC valves and TB.
Finally, for a second opinion, take it to T-3 on Cobb.
