Ignition Coil wiring, cut harness please help!
89240SXCoupe
Car: 1989 Nissan 240SX Coupe XE
Hey, I'm in the process of swapping a 91 ka24de into my 89 coupe, and the engine harness that came with motor has all the ignition coil, resistor and one other plug cut (the plugs after/near the MAFs plug). I searched through the FSM and through the site but couldn't find any wiring diagrams for those 2-3 plugs for the ignition coil system. If anyone could steer me in the right direction with this I would really appreciate it, the motor is cranking and getting fuel and everything else seems fine but I cant seem to wire this ish right to get some spark. Thanks!
89240SXCoupe
Anyone? Can't find anything on that damn wiring.
I'm thinking i might just try to get an uncut engine harness it would probably be easier since mine is cut... If anyone knows about the ignition coil wiring please let me know its all i need to get this car running!!!
