Ignition Coil Test!!!
General discussion area for the L32-chassis Altima
Primodlt
Car: 2011 Nissan Altima SL 2.5
This morning on my way to work 2011 Altima suddenly started running/idling real rough. With no Check Engine light coming on. I did replace cylinder #1 & #4 coils a few months back. How can I test/check the coils with out a multimeter????
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's no good way to check them except swapping, and that doesn't help unless you have a specific cylinder that's misfiring. There are really only five things on an Altie which can cause poor running without generating codes, MAF, fuel pressure, cam sensor, crank sensor, blocked exhaust.
Return to “4th Generation Altima Sedan (2007-2012)”
