ignition coil
Bigrolla
does anyone make a direct replacement coil for ka24de?Or are there any stock coils that will that will increase spark.
Silvia007
Car: 93 Nissan 240SX SE Fastback
I'm not sure if you can just run a aftermarket ignition coil without the respective ignition box... if you can use aftermarket ignition coil without the ignition box, you won't find a direct replacement.
Bigrolla
ok thanx.
