Novajoe »
https://forums.nicoclub.com/novajoe-u184580.html
Thu Jun 09, 2011 5:22 pm
I'm not sure what the webber conversion is so I may be wrong, but I'm fairly certain that vaccume shouldn't fluctuate that far. Have you tried doing a valve lash adjustment? It almost sounds like you have a bad valve/valve seal somewhere. vaccume should only fluctuate about 2psi when idling. This would also give you the power proplems at higher speeds that you're seeing.
I've been shocked plenty of times by spark plugs and it's startling more than it really hurts. If you're grounding out the plug to check for spark and you're getting a solid arc then you should be fine with your spark. Your best bet would be to hit up an autozone and get one of those $5 ign. wire checkers. You should be able to easily diagnose your ign problems if there are any with that.
