Ignition Coil pack
HondoLish
Car: 1993 Infiniti J30
My J30 was running fine untill I changed the plugs. I had one of the coil packs break. Would that cause it to sound like the engine is knocking,Because the coil pack is broken?
driverdriver
Car: NICO's longtime resident Canuck!!!
Did you use OEM NGK sparkplugs? Aftermarket ones are known to cause problems.
Are your injectors fine? Ohm test them, they should be between 10-14 ohms, anything below or above that is failure. Injector failure can cause shaking and knocking. Injector failure is a common age related problem on the J's.
