Anywho, the instruction for the tach's wires are:
White: 12V DashRed: 12V IgnitionBlack: GroundGreen: Negative on ignition coil
I looked in the FSM and on the Ignition coil there is twoharnesses. One harness only has one wire; Black (which isnegative). And the other harness has two wires: Light Green w/Black stripe and Black with Red stripe
I can hook the 12V Ignition to any 12V power source right? Andam I to use the Black ground wire from the one-wire harness thatis in the FSM?
