ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Fri Mar 21, 2003 10:35 am
The only coil upgrades currently are the splitfire coil pack upgrade, but the stock ignitor chip must still be retained. There is also the HKS Twin Power DLI that increases current/voltage sent to the coils, and I don't know if it replaces the ignitor or not (does not include upgraded coils--stock or upgraded coils can be used). The MSD DIS-4 also does the same as the HKS, and I do believe you can do away with the ignitor chip for this.
Vendors for such items can be found at phase2, enjuku, overboost, jspec, and probably more that I have not stumbled upon.
Getting the Splitfire coils with HKS or MSD ignition amplifiers would be quite an insane spark setup.
I am getting the splitfires on order right now because my missfire and stuttering during moderate or high boost. It went away for a little while after changing gaps and stuff, but it has returned in a more severe way. I think my stock coils are getting aged and weak. My spark gap went from .032, .030, .028, and now .025. Each time I lowered my gap, the missing went away (but increased lower rpm miss) and returned later on. This is a giveaway that my spark is getting weaker and weaker.
