mcrews »
https://forums.nicoclub.com/mcrews-u32466.html
Mon Aug 08, 2011 10:46 pm
02Q45 Sport.
I run a scangauge2. It is an obd2 devise that stays plugged in all the time and gives me constant/instant data.
water temp, intake air temp, mpg, mph, volts etc.
I keep it on to help with the mpgs while i'm driving.
Especially on the long trips.
THe ignition advance gauge has shown 31-34 in the past while cruising down the highway at 60-65 w/ the cruise on. while running on pretty flat highway. with 91 octane. engine temp at 193-198.
My last trip to LA from sacramento last week, the ignition advance only was at 27-29 will at 60-65. 91 octane. cruise control on. temp 193-199. rpms 18-1900.
do you have any idea why the advance would drop dowm?
My mileage was also below what I normally get.
I had a p0720 transmission code for about 3 months but got it fixed 2 weeks ago. (the trany was in 4th all the time). Did running this way 'piss off' the ecu?
I dont have any other codes and everything else seem to be running fine.
thqnks in advance
