I have not yet been able to tune with my ignition setup. I plan to rig basically stock ignition system, and control it for starts with a flying magnet pickup system. This is only a temporary solution, (although i will still have 8x8 control) as a distributorless setup is complete minus modified crank damper. With this setup, i will be running a 10btdc base timing, will a full 8x8 as well. Although what i find using the edis distributorless system may be different than a suitable map using stock type system.
Heres a pic of my completed ecu, and palm pilot control. Megasquirt v2.2 with megasquirt&spark/edis modifications. I just like to show it off because i built it
I hate my hosting service, if it doesnt work then paste it in address bar.
