igniter chip gets really hot! and no spark! will explain everything inside! help
firstwizardshawn
Car: 1990 NISSAN 240SX
igniter gets reallt hot when key is left on while trying to find out why no spark is happening! after the second day it done it again and almost burned up # 6 coil pack! car will turn over but not start! i am so close yet so far away i need help! what could be prob! i do get code 21 and everything i see says that ignitor chip is bad am i assuming wrong?
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
one of your power wires is to a ground. Check your ignition relay wiring. should all show 12vdc
Carl H
ignitor is fubard, something in the wiring is wrong.
DJButton
Car: 2010 Nissan 240sx
Eeek and here I am thinking mine is so bad, could be worse I guess huh? Sounds like something is screwing with the ignitor bigtime.
